跳转到主内容
Asus TUF Gaming FX505DY Heat Sink & Fan Replacement
你所需要的
  1. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement, Back Case: 步骤 1 中的图像 1,1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: 步骤 2 中的图像 1,2 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: 步骤 3 中的图像 1,2 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: 步骤 3 中的图像 2,2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: 步骤 4 中的图像 1,2 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: 步骤 4 中的图像 2,2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement, Heat Sink & Fan: 步骤 5 中的图像 1,3 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement, Heat Sink & Fan: 步骤 5 中的图像 2,3 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement, Heat Sink & Fan: 步骤 5 中的图像 3,3
    • With a Phillips 0-bit screwdriver, remove eight 5.0 mm screws on the silver brackets
    • With a Phillips 0-bit screwdriver, remove two 5.0 mm screws holding the edge of the fans in place
  6. Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: 步骤 6 中的图像 1,3 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: 步骤 6 中的图像 2,3 Asus TUF Gaming FX505DY Heat Sink & Fan Replacement: 步骤 6 中的图像 3,3
    • Disconnect two power cables connecting fans to the motherboard.
    • Once all cables and screws are removed, carefully lift up and remove the fans and heat sink
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 72
总计 1,384
