简介
The motherboard is the main part of a device where it controls the whole system and most of the component in the device is connected to it. Extra caution need to be taken as the wire is sensitive and can be easily broken.
你所需要的
Disconnect the dock and make sure the power is turned of.
Use plastic opening tool to pry screen up and remove from outer casing.
Be gentle with the plastic opening tool when you reached the charging port as the thinner plastic could be broken easily.
5等其他人完成本指南。
