跳转到主内容
Asus TF300T Tablet Motherboard Replacement
你所需要的
  1. Asus TF300T Tablet Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 Asus TF300T Tablet Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Disconnect the dock and make sure the power is turned of.
    • Use plastic opening tool to pry screen up and remove from outer casing.
    • Be gentle with the plastic opening tool when you reached the charging port as the thinner plastic could be broken easily.
  2. Asus TF300T Tablet Motherboard Replacement: 步骤 2 中的图像 1,3 Asus TF300T Tablet Motherboard Replacement: 步骤 2 中的图像 2,3 Asus TF300T Tablet Motherboard Replacement: 步骤 2 中的图像 3,3
    • Pull up on the black circuit board protector.
    • Turn off the hard power switch before working with the tablet. Use a tool to slide the switch to the position marked "off".
    • For most of the replacement operation, you do not have to remove the battery once you turned off the switch. Make sure that you do not short anything with the metal tools.
  3. Asus TF300T Tablet Motherboard Replacement: 步骤 3 中的图像 1,2 Asus TF300T Tablet Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #00 Screwdriver to remove nine 3mm screws that is connected to the motherboard.
    • Use tweezers to remove connected part as shown in the picture.
  4. Asus TF300T Tablet Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the motherboard using the plastic opening tool gently.
结论
5等其他人完成本指南。
团队
IUPUI, Team S2-G2, Wilson Summer 2017 IUPUI, Team S2-G2, Wilson Summer 2017 的会员
IUPUI-WILSON-SU17S2G2
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 30
总计 1,471
