跳转到主内容
Asus TF300T Tablet Front Facing Camera Replacement
你所需要的
  1. Asus TF300T Tablet Front Facing Camera Replacement, Front Facing Camera: 步骤 1 中的图像 1,2 Asus TF300T Tablet Front Facing Camera Replacement, Front Facing Camera: 步骤 1 中的图像 2,2
    • Disconnect the dock and make sure the power is turned off.
    • Use plastic opening tool to pry screen up and remove the main tablet body from outer rim casing.
    • Be gentle with the plastic opening tool near charging port. The thinner plastic may break easily.
  2. Asus TF300T Tablet Front Facing Camera Replacement: 步骤 2 中的图像 1,3 Asus TF300T Tablet Front Facing Camera Replacement: 步骤 2 中的图像 2,3 Asus TF300T Tablet Front Facing Camera Replacement: 步骤 2 中的图像 3,3
    • Pull up on the black circuit board protector.
    • Turn off the hard power switch before working with the tablet. Use plastic tool to slide the switch to the position marked "off".
    • For most of the replacement operation, you do not have to remove the battery once you turned off the switch. Make sure that you do not short anything with the metal tools.
  3. Asus TF300T Tablet Front Facing Camera Replacement: 步骤 3 中的图像 1,3 Asus TF300T Tablet Front Facing Camera Replacement: 步骤 3 中的图像 2,3 Asus TF300T Tablet Front Facing Camera Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use a Phillips #00 Screwdriver to remove the six 3mm screws that connect the upper part of the motherboard.
    • Use tweezers to remove red connecting wires. Remove the motherboard by lifting it upward.
  4. Asus TF300T Tablet Front Facing Camera Replacement: 步骤 4 中的图像 1,1
    • Use tweezers to pull out the gold flap connected to the front camera.
    • Pull the disconnected gold flap to take out the camera.
结论
Emma Sloan
于05/17/17注册
101 声望
撰写一个指南
团队
IUPUI, Team S2-G2, Wilson Summer 2017 IUPUI, Team S2-G2, Wilson Summer 2017 的会员
IUPUI-WILSON-SU17S2G2
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 312
