跳转到主内容
Asus Rog GL55VW-DH71 Speaker Replacement
你所需要的
  1. Asus Rog GL55VW-DH71 Speaker Replacement, Battery: 步骤 1 中的图像 1,3 Asus Rog GL55VW-DH71 Speaker Replacement, Battery: 步骤 1 中的图像 2,3 Asus Rog GL55VW-DH71 Speaker Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the laptop over so the backside is facing upwards.
    • Using both hands, slide the lock mechanisms outwards and pull up to remove the battery.
  2. Asus Rog GL55VW-DH71 Speaker Replacement, Keyboard: 步骤 2 中的图像 1,3 Asus Rog GL55VW-DH71 Speaker Replacement, Keyboard: 步骤 2 中的图像 2,3 Asus Rog GL55VW-DH71 Speaker Replacement, Keyboard: 步骤 2 中的图像 3,3
    • Remove the nine 15.4mm Phillips #00 screws.
    • Remove the four 8.7mm Phillips #00 screws from the hard drive mounting bracket.
    • Remove the hard drive bracket.
  3. Asus Rog GL55VW-DH71 Speaker Replacement: 步骤 3 中的图像 1,2 Asus Rog GL55VW-DH71 Speaker Replacement: 步骤 3 中的图像 2,2
    • Flip laptop over and open the screen.
    • Wedge some plastic opening tools between the keyboard and case.
    • Work your way around with the plastic opening tools until the keyboard is separate from the case.
    • Do not try to lift the keyboard straight off at this time. There are some ribbon cables that attach the motherboard to the keyboard that need to be removed first.
  4. Asus Rog GL55VW-DH71 Speaker Replacement: 步骤 4 中的图像 1,3 Asus Rog GL55VW-DH71 Speaker Replacement: 步骤 4 中的图像 2,3 Asus Rog GL55VW-DH71 Speaker Replacement: 步骤 4 中的图像 3,3
    • Remove the ZIF connected ribbon cables for the touchpad and keyboard by gently lifting the latch on the connector point, then slide the ribbon cable out. Repeat for each cable.
    • Verify all ribbon cables are disconnected and out of the way, and lift the keyboard out of the assembly.
  5. Asus Rog GL55VW-DH71 Speaker Replacement, Asus Rog GL55VW-DH71 Disassembly: 步骤 5 中的图像 1,1
    • Remove the CD/DVD drive by sliding it out of the side of the laptop.
  6. Asus Rog GL55VW-DH71 Speaker Replacement: 步骤 6 中的图像 1,3 Asus Rog GL55VW-DH71 Speaker Replacement: 步骤 6 中的图像 2,3 Asus Rog GL55VW-DH71 Speaker Replacement: 步骤 6 中的图像 3,3
    • Remove the three 6.5mm Phillips #00 screws from the fan.
    • Disconnect the fan power cable from the motherboard.
    • Remove the fan.
  7. Asus Rog GL55VW-DH71 Speaker Replacement: 步骤 7 中的图像 1,3 Asus Rog GL55VW-DH71 Speaker Replacement: 步骤 7 中的图像 2,3 Asus Rog GL55VW-DH71 Speaker Replacement: 步骤 7 中的图像 3,3
    • Gently remove the ribbon cables and wireless chip. A plastic prying tool will help in this removal.
    • Remove the power cable for the motherboard.
    • Remove the power cable for the speaker.
  8. Asus Rog GL55VW-DH71 Speaker Replacement: 步骤 8 中的图像 1,1
    • Ensuring no missed connections or screws, remove the motherboard from the assembly.
  9. Asus Rog GL55VW-DH71 Speaker Replacement, Speaker: 步骤 9 中的图像 1,2 Asus Rog GL55VW-DH71 Speaker Replacement, Speaker: 步骤 9 中的图像 2,2
    • Move the wireless chip to the side.
  10. Asus Rog GL55VW-DH71 Speaker Replacement: 步骤 10 中的图像 1,3 Asus Rog GL55VW-DH71 Speaker Replacement: 步骤 10 中的图像 2,3 Asus Rog GL55VW-DH71 Speaker Replacement: 步骤 10 中的图像 3,3
    • Using a metal spudger, pry the speakers from the assembly.
    • Pull the cables for each speaker from the cable channels gently and remove speakers from the assembly.
结论
2等其他人完成本指南。
Addison Thomas
于02/14/18注册
1,232 声望
创作了8篇指南
团队
USF Tampa, Team S1-G2, Nance Spring 2018 USF Tampa, Team S1-G2, Nance Spring 2018 的会员
USFT-NANCE-S18S1G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 2,744
