跳转到主内容
Asus ROG Zephyrus S (GX531GS-AH76) Upgrades
你所需要的
  1. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Prepare Laptop, Tools and New Components: 步骤 1 中的图像 1,3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Prepare Laptop, Tools and New Components: 步骤 1 中的图像 2,3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Prepare Laptop, Tools and New Components: 步骤 1 中的图像 3,3
    • First, unplug anything that is plugged into the ports of the laptop.
    • Next, Shut Down the laptop completely.
    • Make sure you have the tools you need and make sure you have space to work unobstructed.
  2. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Fan Cover: 步骤 2 中的图像 1,3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Fan Cover: 步骤 2 中的图像 2,3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Fan Cover: 步骤 2 中的图像 3,3
    • Next, flip your laptop upside down and remove the 2 sets of screws highlighted in yellow with your Phillips 0 screwdriver, There are 2 sets of 2.
    • Then open the laptop to roughly 45 degrees and place it on its side as shown. From this position you can wiggle the dust cover off.
    • If you are having trouble then open or close the lid a little further. When you have it in the right position it will require no force, it will slide right off.
  3. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Screws, Screws, Screws: 步骤 3 中的图像 1,3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Screws, Screws, Screws: 步骤 3 中的图像 2,3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Screws, Screws, Screws: 步骤 3 中的图像 3,3
    • Now remove the 13 Philips 0 screws marked in yellow .
    • Make sure you only remove the screws that are circled. There are a few that are not circled and do not need to be removed.
    • Next remove the 6 T5 Torx screws circled in orange
    • flip the laptop over and you are going to gently pry the hinge cover off.
    • Once loose, carefully disconnect the 2 cables marked in yellow that are attaching it to the motherboard.
  4. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Keyboard Removal: 步骤 4 中的图像 1,3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Keyboard Removal: 步骤 4 中的图像 2,3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Keyboard Removal: 步骤 4 中的图像 3,3
    • It should now look like this.
    • Now flip open the lid. Use your opening tool to pry apart the seam shown.
    • Work your way around the seam until it is loose all the way around but do not lift the keyboard off yet.
  5. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Keyboard: 步骤 5 中的图像 1,3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Keyboard: 步骤 5 中的图像 2,3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Keyboard: 步骤 5 中的图像 3,3
    • Very carefully lift the keyboard from the side closest to the screen while not pulling the attaching cables too tight
    • .Once you have space to reach in, then you can unclip the 4 cables from their connectors marked with yellow boxes here and then set the entire keyboard assembly to the side.
    • Your laptop should look like this now.
    • The yellow box on the left is around the SSD and the one on the right is the RAM.
  6. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove the Old RAM: 步骤 6 中的图像 1,2 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove the Old RAM: 步骤 6 中的图像 2,2
    • Push the retaining clip on each side of the RAM module to the left and right away from it. This will release the RAM and it will pop up at a 45 degree angle. You can now slide it out.
    • Next slide your new stick of RAM in and push it down until it clicks.
  7. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Old SSD: 步骤 7 中的图像 1,3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Old SSD: 步骤 7 中的图像 2,3 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Remove Old SSD: 步骤 7 中的图像 3,3
    • Next, fold the ribbon out of the way that is covering the SSD and remove the SSD retaining screw.
    • Now gently pry up on that same end until it lifts off the sticky thermal pad underneath. It doesn't take much. Once you are clear of the pad you can pull the SSD out of it's M.2 socket.
    • Now install your new SSD and secure it with the retaining screw.
  8. Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Cleaning then Re-assembly: 步骤 8 中的图像 1,2 Asus ROG Zephyrus S (GX531GS-AH76) Upgrades, Cleaning then Re-assembly: 步骤 8 中的图像 2,2
    • While it is apart, clean your fans from above and underneath. Get all the dust out you can. Once done you can start putting it back together in reverse order.
结论
28等其他人完成本指南。
TooMuchSauce
于12/30/18注册
1,533 声望
撰写一个指南
34条评论
What about the software on the old drive, operating system and all? How to clone the m.2 drive?
Steve Del Hoyo - 回复
I used an external m.2 enclosure like the one I’ll link below and the free maxium reflect software to clone my existing drive. Once the swap is completed you can use the enclosure with your old ssd as an external drive if you want. https://www.amazon.com/Sabrent-NGFF-Alum...
TooMuchSauce - 回复
The $12 or $45 one? There are two on that Amazon link
willshahbazian -
The product on that link has changed but I would use the $50 one depending on the SSD you buy.
TooMuchSauce -
Thank you! It worked for me
willshahbazian -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 28
过去 30 天: 127
总计 33,442
