简介
The CD drive is a component that is susceptible to fail overtime. Generally, a failing CD drive makes clicking sounds, and the disks inserted cannot be read by the computer. If your CD drive is no longer reading the CD disk or making clicking sounds, it might be time to replace the CD drive. This guide will walk you through the steps needed to remove the CD drive from your device.
你所需要的
Remove the 9 mm and 16 mm screws on the back panel using the Philips #1 screw driver.
即将完成!
结论
