跳转到主内容
Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement
你所需要的
  1. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Back Panel: 步骤 1 中的图像 1,2 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 步骤 2 中的图像 1,3 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 步骤 2 中的图像 2,3 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 步骤 2 中的图像 3,3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Battery: 步骤 3 中的图像 1,1
    • Unplug the battery from the motherboard.
  4. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 步骤 4 中的图像 1,3 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 步骤 4 中的图像 2,3 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 步骤 4 中的图像 3,3
    • Unscrew the 3.8 mm Phillips #1 screw on the top right hand corner of the battery.
    • Lift battery from laptop frame.
  5. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Wifi Card: 步骤 5 中的图像 1,3 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Wifi Card: 步骤 5 中的图像 2,3 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Wifi Card: 步骤 5 中的图像 3,3
    • Using the iFixit Opening Tool, disconnect the black and white coaxial cables from the wifi card.
    • Using a Phillips #1 screwdriver, remove the 4mm retaining screw.
    • Gently slide the wifi card out from the connection slot.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 49
总计 2,360
