跳转到主内容
Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement
你所需要的
  1. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,2 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 2 中的图像 1,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 2 中的图像 2,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 2 中的图像 3,3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Battery: 步骤 3 中的图像 1,1
    • Unplug the battery from the motherboard.
  4. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 4 中的图像 1,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 4 中的图像 2,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Unscrew the 3.8 mm Phillips #1 screw on the top right hand corner of the battery.
    • Lift battery from laptop frame.
  5. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the four 4 mm screws holding the hard drive.
  6. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Pull the hard drive directly away from the fan just above it.
    • The connecting pins should slide out easily, but you might have to move the hard drive around a bit to loosen the pins.
  7. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Fan: 步骤 7 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the four indicated 4 mm screws that hold the black fan and the silver one adjacent to it.
  8. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 8 中的图像 1,1
    • The smaller black fan must be removed before the larger gray fan on the right can be taken out.
    • To remove the black fan, pull gently on the connecting cables outlined.
  9. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Unplug the white connector by gently pulling the cables.
    • Lift off the gray fan.
  10. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the two indicated 4 mm screws from the other gray fan.
  11. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 11 中的图像 1,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 11 中的图像 2,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 11 中的图像 3,3
    • Unplug the white connector by gently pulling it towards the center of the computer.
    • Lift the fan out of the body of the laptop to remove it.
  12. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Motherboard: 步骤 12 中的图像 2,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Motherboard: 步骤 12 中的图像 3,3
    • Disconnect the speakers connectors located in each of the bottom corners.
    • Gently pull the wire up from the motherboard.
    • Once the wire is disconnected, pull the speaker out.
  13. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 13 中的图像 1,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 13 中的图像 2,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 13 中的图像 3,3
    • Gently lift the graphics card from the motherboard.
  14. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 14 中的图像 1,2 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Use reverse pliers to detach ribbon connectors from the motherboard.
  15. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 15 中的图像 1,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 15 中的图像 2,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 15 中的图像 3,3
    • Remove each of the 4.7 mm Phillips #1 screws marked by a white arrow on the motherboard.
    • Remove the 6.7 mm Phillips #1 screws from the metal latches on the hinge-side corners.
    • The 4.7 mm Phillips #1 screw on the far left of the motherboard is covered by the black connecting wire in Step 5.
  16. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 16 中的图像 1,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 16 中的图像 2,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 16 中的图像 3,3
    • Gently pull on black connecting wire to disconnect the monitor screen from the motherboard.
    • This will uncover the far left 4.7 mm Phillips #1 screw.
  17. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 17 中的图像 1,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 17 中的图像 2,3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 17 中的图像 3,3
    • Lift the metal latches on both sides.
    • This can be easily done by opening the laptop after the metal latch screws have been removed.
  18. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: 步骤 18 中的图像 1,1
    • Remove the motherboard from the laptop frame.
    • You will need to pull the motherboard to the side as well as lifting it to free its various ports from the sides of the laptop case.
    • There is adhesive attaching the final ribbon connector to the bottom of the motherboard. This will need to be removed.
结论
一条评论
OK but where can I actually buy the replacement motherboard?
Hank Muller - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 33
总计 3,098
