跳转到主内容
Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement
你所需要的
  1. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Back Panel: 步骤 1 中的图像 1,2 Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: 步骤 2 中的图像 1,3 Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: 步骤 2 中的图像 2,3 Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the four 4 mm screws holding the hard drive.
  4. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Pull the hard drive directly away from the fan just above it.
    • The connecting pins should slide out easily, but you might have to move the hard drive around a bit to loosen the pins.
结论
8等其他人完成本指南。
Zach Langer
于04/10/17注册
676 声望
创作了4篇指南
团队
Cal Poly, Team S13-G2, Forte Spring 2017 Cal Poly, Team S13-G2, Forte Spring 2017 的会员
CPSU-FORTE-S17S13G2
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 7,114
