跳转到主内容
Asus ROG Strix GL553VD Battery Replacement
你所需要的
  1. Asus ROG Strix GL553VD Battery Replacement, Battery: 步骤 1 中的图像 1,2 Asus ROG Strix GL553VD Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Use a JIS screwdriver to remove the ten 4 mm screws from the bottom cover.
  2. Asus ROG Strix GL553VD Battery Replacement: 步骤 2 中的图像 1,2 Asus ROG Strix GL553VD Battery Replacement: 步骤 2 中的图像 2,2
    • Open the flap in the middle to reveal the 11th screw and remove it using the same JIS screwdriver.
  3. Asus ROG Strix GL553VD Battery Replacement: 步骤 3 中的图像 1,3 Asus ROG Strix GL553VD Battery Replacement: 步骤 3 中的图像 2,3 Asus ROG Strix GL553VD Battery Replacement: 步骤 3 中的图像 3,3
    • Gently lift each corner to remove the cover from the laptop.
    • If you seem to have difficulty removing the cover, you may use a plastic opening tool to pry up one of the corners to get you started.
  4. Asus ROG Strix GL553VD Battery Replacement: 步骤 4 中的图像 1,3 Asus ROG Strix GL553VD Battery Replacement: 步骤 4 中的图像 2,3 Asus ROG Strix GL553VD Battery Replacement: 步骤 4 中的图像 3,3
    • Gently pull the white battery connector out towards the battery.
  5. Asus ROG Strix GL553VD Battery Replacement: 步骤 5 中的图像 1,1
    • Carefully lift the battery out from the case to remove it.
    • The battery will come off easily as the screws are already removed.
结论
4等其他人完成本指南。
Mahmoud Mehdi
于09/20/20注册
247 声望
撰写一个指南
团队
一条评论
Thank you for the guide. It was tricky to find the screw in the middle, hidden behind the flap. The screws are however not torx as shown.
Soheil Roshanbin - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 75
总计 4,455
