跳转到主内容
Asus ROG GL551J Screen Replacement
你所需要的
  1. Asus ROG GL551J Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Screen Replacement: 步骤 2 中的图像 1,1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Screen Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out.
  4. Asus ROG GL551J Screen Replacement, Screen: 步骤 4 中的图像 1,2 Asus ROG GL551J Screen Replacement, Screen: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to remove the plastic hinge covers on either side of the laptop.
  5. Asus ROG GL551J Screen Replacement: 步骤 5 中的图像 1,2 Asus ROG GL551J Screen Replacement: 步骤 5 中的图像 2,2
    • Remove the middle screws located on either side of the display.
  6. Asus ROG GL551J Screen Replacement: 步骤 6 中的图像 1,2 Asus ROG GL551J Screen Replacement: 步骤 6 中的图像 2,2
    • Use a plastic opening tool to pop out the bezel from all four sides, then lift it out of the frame.
    • When doing this in reverse during reassembly, try closing the laptop and applying pressure to reattach the bezel snaps.
  7. Asus ROG GL551J Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the screws at each corner of the display.
  8. Asus ROG GL551J Screen Replacement: 步骤 8 中的图像 1,2 Asus ROG GL551J Screen Replacement: 步骤 8 中的图像 2,2
    • Remove the connector from the display by pulling the wire downwards.
    • Be sure to take note of the orientation of the connector when unplugging and plugging in.
结论
另外一个人完成了本指南。
Thien Vu
于02/15/17注册
412 声望
创作了2篇指南
团队
USF Tampa, Team 5-4, Lacy Spring 2017 USF Tampa, Team 5-4, Lacy Spring 2017 的会员
USFT-LACY-S17S5G4
4 名成员
创作了5篇指南
一条评论
Hey, I am having issues putting the plastic hinge caps back on after I'm done. I know there is a right one and a left one but I just don't know how to pop them back into place. Starting to get a bit desperate. Could anyone give me some tips?
Thanks!
Teodor Andonov - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 3,024
