跳转到主内容
Asus ROG GL551J Optical Drive Replacement
你所需要的
  1. Asus ROG GL551J Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out.
  4. Asus ROG GL551J Optical Drive Replacement, Optical Drive: 步骤 4 中的图像 1,2 Asus ROG GL551J Optical Drive Replacement, Optical Drive: 步骤 4 中的图像 2,2
    • Locate and unscrew the screw which connects the optical drive to the chassis
  5. Asus ROG GL551J Optical Drive Replacement: 步骤 5 中的图像 1,1
    • Grasp the edge of the optical drive
  6. Asus ROG GL551J Optical Drive Replacement: 步骤 6 中的图像 1,1
    • Pull on the optical drive gently. With little resistance, the optical drive should just slide out
结论
4等其他人完成本指南。
Philip Muino
于02/15/17注册
179 声望
撰写一个指南
团队
USF Tampa, Team 5-4, Lacy Spring 2017 USF Tampa, Team 5-4, Lacy Spring 2017 的会员
USFT-LACY-S17S5G4
4 名成员
创作了5篇指南
一条评论
ok.so , if someone had replaced the dvd rom with a hard disk drive i nust do the same for replace the drive?
anix - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 1,961
