跳转到主内容
Asus ROG GL551J Hard Drive Replacement
你所需要的
  1. Asus ROG GL551J Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the device on a flat surface with the battery facing up.
    • Be sure to wear ESD or Rubber gloves to protect the computer components.
  2. Asus ROG GL551J Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Push the latch found below the battery to the unlock position.
  3. Asus ROG GL551J Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out.
  4. Asus ROG GL551J Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,2 Asus ROG GL551J Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • With laptop upside-down, locate and unscrew the two screws on the panel with the vents.
    • Slide the panel out and lift up to remove.
  5. Asus ROG GL551J Hard Drive Replacement: 步骤 5 中的图像 1,2 Asus ROG GL551J Hard Drive Replacement: 步骤 5 中的图像 2,2
    • The hard drive is the metal rectangle with the two soft padding bars attached to it.
    • Locate and remove the 4 screws holding the hard drive down at each corner using a PH000 Philips head.
  6. Asus ROG GL551J Hard Drive Replacement: 步骤 6 中的图像 1,2 Asus ROG GL551J Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Locate the black plastic tab attached to the bottom of the hard drive and pull it straight outwards.
    • Failure to correctly disconnect the hard drive before pulling it up and out can damage the connectors.
    • Once the hard drive detaches from the connector, lift the hard drive up and out.
结论
7等其他人完成本指南。
Thien Vu
于02/15/17注册
412 声望
创作了2篇指南
团队
USF Tampa, Team 5-4, Lacy Spring 2017 USF Tampa, Team 5-4, Lacy Spring 2017 的会员
USFT-LACY-S17S5G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 4,459
