跳转到主内容
Asus ROG G752V Battery Replacement
你所需要的
  1. Asus ROG G752V Battery Replacement, Battery: 步骤 1 中的图像 1,2 Asus ROG G752V Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure you disconnect the charger before starting this guide.
    • Pick out all 11 rubber plugs off of the back cover with a pair of tweezers.
  2. Asus ROG G752V Battery Replacement: 步骤 2 中的图像 1,2 Asus ROG G752V Battery Replacement: 步骤 2 中的图像 2,2
    • Using the Phillips #0 screwdriver, unscrew all twelve 5.2 mm screws on the back of the laptop.
    • There is one 5.2 mm screw under the rubber plug in the middle.
    In my case, the 4 screws alongside the touchpad are smaller than the others.
    Jonathan Deeb - 回复
  3. Asus ROG G752V Battery Replacement: 步骤 3 中的图像 1,1
    • Pull up the rubber seal and the service cover will come off.
  4. Asus ROG G752V Battery Replacement: 步骤 4 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the six 5.2 mm screws under the service cover.
    The bottom red circle should be 1/2” to the right.
    y2l2 - 回复
  5. Asus ROG G752V Battery Replacement: 步骤 5 中的图像 1,1
    • Using your hands, pull the optical drive out.
    You will need a small safety pin or similar to release the CD drive tray so it can open. Look for a small hole and insert the pin into the hole and push, it should normally open the tray.
    Once open, look for 3 small screws that are attached to the cover. These have to be removed so the cover can come off.
    Build It - 回复
  6. Asus ROG G752V Battery Replacement: 步骤 6 中的图像 1,2 Asus ROG G752V Battery Replacement: 步骤 6 中的图像 2,2
    • Use the iFixit Opening Tool to pry apart the back panel from the main body of the laptop.
    • Start from the front side of the laptop and then continue to the side for easier access.
  7. Asus ROG G752V Battery Replacement: 步骤 7 中的图像 1,2 Asus ROG G752V Battery Replacement: 步骤 7 中的图像 2,2
    • Remove the hinge on the back of the laptop cover using the iFixit Opening Tool. The piece should pop off.
    • Be gentle with the cover because there is a speaker wire attached to it.
  8. Asus ROG G752V Battery Replacement: 步骤 8 中的图像 1,2 Asus ROG G752V Battery Replacement: 步骤 8 中的图像 2,2
    • Disconnect the speaker wire.
  9. Asus ROG G752V Battery Replacement: 步骤 9 中的图像 1,2 Asus ROG G752V Battery Replacement: 步骤 9 中的图像 2,2
    • Slowly pull out the keyboard while lifting it about an inch.
    • There are cables attached to the keyboard and motherboard. DO NOT lift it more than 2 inches above the laptop.
  10. Asus ROG G752V Battery Replacement: 步骤 10 中的图像 1,3 Asus ROG G752V Battery Replacement: 步骤 10 中的图像 2,3 Asus ROG G752V Battery Replacement: 步骤 10 中的图像 3,3
    • Using an ESD safe tool, detach all 3 ribbon cables securing the keyboard to the laptop.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    Do you do the same thing in Reverse lift the flap up place the ribbon down and then it's snaps?
    Reaper Grimm - 回复
    I didn't need to disconnect the ribbons, just slide the keyboard forward a few inches for the following steps
    Jason B - 回复
  11. Asus ROG G752V Battery Replacement: 步骤 11 中的图像 1,2 Asus ROG G752V Battery Replacement: 步骤 11 中的图像 2,2
    • Once the cables are detached, lift the keyboard about 2 inches up and remove it from the rest of the body.
    • Make sure that the screen is open like the photo. This will ensure that none your laptop components will not be bent.
  12. Asus ROG G752V Battery Replacement: 步骤 12 中的图像 1,3 Asus ROG G752V Battery Replacement: 步骤 12 中的图像 2,3 Asus ROG G752V Battery Replacement: 步骤 12 中的图像 3,3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the left of the socket.
    • Pull parallel to the motherboard, not straight up.
  13. Asus ROG G752V Battery Replacement: 步骤 13 中的图像 1,3 Asus ROG G752V Battery Replacement: 步骤 13 中的图像 2,3 Asus ROG G752V Battery Replacement: 步骤 13 中的图像 3,3
    • Remove two 5.8 mm screws holding the screen and the laptop located at the hinge.
    • This will unlatch the screen from the laptop entirely.
    • Remove the screen.
    In my case, 6 x M2.4x9,6mm screws near the center - indicated with X stamp - and 2 x M1,9x6,6mm screws, 1 on the left hand side and the other on the right hand side.
    Jonathan Deeb - 回复
    Mine same as Jonathan’s. Total of 8 screws to remove the screen
    Don Dunlop - 回复
  14. Asus ROG G752V Battery Replacement: 步骤 14 中的图像 1,1
    • Remove the four 5.8 mm screws securing the battery to the laptop.
    There are two different lengths of screw holding the battery. When putting it back together, the longer screws go to the rear of the computer.
    Greg S. - 回复
  15. Asus ROG G752V Battery Replacement: 步骤 15 中的图像 1,1
    • Use your hands to remove the battery.
    • If you're having trouble, push down on the black plastic on the screen side of the battery. This should release the battery.
    The second set of wires going to the battery (shown on the right side between the tech's thumb and forefinger) are attached to a strip glued to the back of the battery. I believe it is a temperature sensor of some kind. Carefully peel it off the old battery, being careful not to bend it and press it to onto the new battery. There are two holes in the sensor strip, on at the right in the corner, another at the left end in the center. On the battery, there are two very small, hard to see alignment points to fit into those holes.
    Greg S. - 回复
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
12等其他人完成本指南。
10条评论
There is 2 connection. What is the smaller connection for? Thanks.
Micky Max - 回复
The second set of wires going to the battery (shown on the right side between the tech's thumb and forefinger in the picture at the step where you remove the battery) are attached to a strip glued to the back of the battery. I believe it is a temperature sensor of some kind. Carefully peel it off the old battery, being careful not to bend it and press it to onto the new battery. There are two holes in the sensor strip, on at the right in the corner, another at the left end in the center. On the battery, there are two very small, hard to see alignment points to fit into those holes.
I see where Rich C says it's part of an LED strip. I didn't look at it closely.
Greg S. -
God, alot of people looked at my team’s project. Sorry it’s a piece of crap.
I had to do it for my tech writing class, got a solid B on it.
Jeong - 回复
Thanks for this write up, excellent job. As Mickey mentioned, there is a second connection, from the side of the existing battery. This is actually part of an LED strip that is secured to the battery with an adhesive strip. Some models have this glowing back panel. I used a filet knife to pop the LED panel off the old battery and then tack it on the new one.
Rich C - 回复
My lap top bears no relation to this but it is a UK spec laptop so may differ. I will need to purchase a kit from iFixit before I embark on replacing the battery in my laptop
Gerald Talbot - 回复
This was a lot easier than I anticipated. I want to thank you for your excellent writeup which was a lot better than the videos I have seen on YouTube.
Nemo Blades - 回复
Thanks to the Asus ROG G752V Battery Replacement tutorial, I have successfully replaced
batterie dell - 回复
you forgot one important detail betwen step 5 and step 6 - there are three screws beneath the optical drive, when you slide it out they need to be removed first before popping the case (you can see where they go on the left side of the image in step 14, along the outer edge of the empty optical drive bay)
otherwise, fantastic, very helpful
Mike Strickland - 回复
Amazing directions,
If I feel uneasy doing it myself, where would be a qualified place to have someone do it
caldens11 - 回复
My wifi connection quit working after I replaced the battery.
Before you put everything back together, check the antenna wires are connected to the wifi card. If you look at picture 14 in these instructions, the wifi card is located roughly under the guys thumb. There is a white and a black wire with snap on connectors about the size of a pinhead.
If you still aren't sure, Jeong has another excellent article at Asus ROG G752V Wireless Card Replacement.
Greg S. - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 55
过去 30 天: 236
总计 20,817
