跳转到主内容
Asus ROG G751JT-DH72 RAM Replacement
你所需要的
  1. Asus ROG G751JT-DH72 RAM Replacement, RAM: 步骤 1 中的图像 1,2 Asus ROG G751JT-DH72 RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Lift up the rubber tab located in the upper-right corner of the backing plate.
  2. Asus ROG G751JT-DH72 RAM Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the 5.2 mm screw behind the rubber tap.
  3. Asus ROG G751JT-DH72 RAM Replacement: 步骤 3 中的图像 1,1
    • Carefully pull the backing plate off. If you have a pry tool, you can pry on the edges carefully.
  4. Asus ROG G751JT-DH72 RAM Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the 5mm screw on the right side.
  5. Asus ROG G751JT-DH72 RAM Replacement: 步骤 5 中的图像 1,1
    • Pull out the optical drive to revel the screws holding the laptop cover.
  6. Asus ROG G751JT-DH72 RAM Replacement: 步骤 6 中的图像 1,2 Asus ROG G751JT-DH72 RAM Replacement: 步骤 6 中的图像 2,2
    • Remove all 10 5.2mm Phillips screws holding the main back cover using the Phillips #1 screwdriver.
  7. Asus ROG G751JT-DH72 RAM Replacement: 步骤 7 中的图像 1,1
    • Remove the four 5.2mm screws directly behind the backing plate using the Phillips #1 screwdriver.
  8. Asus ROG G751JT-DH72 RAM Replacement: 步骤 8 中的图像 1,1
    • Flip over the laptop and pry the 2 vent covers off.
  9. Asus ROG G751JT-DH72 RAM Replacement: 步骤 9 中的图像 1,1
    • Remove the two 6.8mm Phillips screws directly below the vent covers using the Phillips #1 screwdriver.
  10. Asus ROG G751JT-DH72 RAM Replacement: 步骤 10 中的图像 1,2 Asus ROG G751JT-DH72 RAM Replacement: 步骤 10 中的图像 2,2
    • Pry along the edges of the keyboard to lift it up.
    • Be careful not to damage the ribbon connectors.
  11. Asus ROG G751JT-DH72 RAM Replacement: 步骤 11 中的图像 1,2 Asus ROG G751JT-DH72 RAM Replacement: 步骤 11 中的图像 2,2
    • Disconnect all 4 ribbon connectors with a tweezer.
  12. Asus ROG G751JT-DH72 RAM Replacement: 步骤 12 中的图像 1,1
    • Carefully, pull on the side tabs to release the RAM card.
结论
Anum Haidari
于10/22/18注册
558 声望
创作了3篇指南
团队
UC Davis, Team S7-G4, Lore Fall 2018 UC Davis, Team S7-G4, Lore Fall 2018 的会员
UCD-LORE-F18S7G4
2 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,169
