跳转到主内容
Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement
你所需要的
  1. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement, Left and Right Track Pad Buttons: 步骤 1 中的图像 1,2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement, Left and Right Track Pad Buttons: 步骤 1 中的图像 2,2
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
  2. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 2 中的图像 1,3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 2 中的图像 2,3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 2 中的图像 3,3
    • Use the standard spudger to remove the back center panel.
  3. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 3 中的图像 1,3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 3 中的图像 2,3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
  4. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 4 中的图像 1,2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 4 中的图像 2,2
    • Pull out the optical drive found on the side of the laptop.
  5. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 5 中的图像 1,3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 5 中的图像 2,3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 5 中的图像 3,3
    • Remove the screws holding the hard drives in place using a Phillips 1 screwdriver.
    • Using the small flaps, remove the hard drives by hand.
  6. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 6 中的图像 1,2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  7. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 7 中的图像 1,2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 7 中的图像 2,2
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  8. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 8 中的图像 1,3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 8 中的图像 2,3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 8 中的图像 3,3
    • Use a metal spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
  9. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 9 中的图像 1,1
    • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
  10. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 10 中的图像 1,1
    • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
  11. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 11 中的图像 1,3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 11 中的图像 2,3 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 11 中的图像 3,3
    • Use a metal spudger to pry the keyboard from the base of the laptop.
    • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
  12. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 12 中的图像 1,2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 12 中的图像 2,2
    • Use a pair of tweezers to undo each of the four ribbon connectors.
    • The keyboard is now completely disconnected from the laptop and you can remove it.
  13. Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 13 中的图像 1,2 Asus ROG G751JL-DS71 Left and Right Track Pad Buttons Replacement: 步骤 13 中的图像 2,2
    • Use a pair of tweezers to undo each of the two ribbon connectors.
    • The Left and right button is now completely disconnected from the laptop and you can remove it.
结论
3等其他人完成本指南。
团队
IUPUI, Team S8-G8, Wilson Spring 2019 IUPUI, Team S8-G8, Wilson Spring 2019 的会员
IUPUI-WILSON-S19S8G8
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 1,118
