跳转到主内容
简介
This guide will show the user how to safely remove and replace the battery.
  1. Lift the rubber cover found on the bottom of the laptop. Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
    • Lift the rubber cover found on the bottom of the laptop.
    • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
  2. Use the nylon spudger to remove the back center panel. Use the nylon spudger to remove the back center panel. Use the nylon spudger to remove the back center panel.
    • Use the nylon spudger to remove the back center panel.
  3. Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel. Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
    • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
  4. Pull out the optical drive found on the side of the laptop. Pull out the optical drive found on the side of the laptop.
    • Pull out the optical drive found on the side of the laptop.
  5. Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop. Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
    • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  6. Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws. Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
    • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  7. Use a nylon spudger to carefully pry the top back panel off. While removing the top back panel, be careful not to break the four pin connector located underneath. Disconnect the four-pin connector and remove the top back panel from the computer.
    • Use a nylon spudger to carefully pry the top back panel off.
    • While removing the top back panel, be careful not to break the four pin connector located underneath.
    • Disconnect the four-pin connector and remove the top back panel from the computer.
  8. Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel. Lift away the metal housings from each side of the laptop. Lift away the metal housings from each side of the laptop.
    • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
    • Lift away the metal housings from each side of the laptop.
  9. Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place. Use a Phillips 1 Screwdriver to remove  the four 5.2 mm screws underneath the center panel.
    • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
    • Use a Phillips 1 Screwdriver to remove the four 5.2 mm screws underneath the center panel.
  10. Use a plastic opening tool to pry the keyboard from the base of the laptop. Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard. Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
    • Use a plastic opening tool to pry the keyboard from the base of the laptop.
    • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
  11. Use a pair of tweezers to undo each of the four ribbon connectors. The keyboard is now completely disconnected from the laptop and you can remove it.
    • Use a pair of tweezers to undo each of the four ribbon connectors.
    • The keyboard is now completely disconnected from the laptop and you can remove it.
  12. Use a pair of tweezers to carefully disconnect the pin connector. Use a pair of tweezers to carefully disconnect the pin connector.
    • Use a pair of tweezers to carefully disconnect the pin connector.
  13. Use a Phillips 1 Screwdriver to remove the final four remaining 6.8 mm screws located underneath the back panel. The monitor is now free to be completely lifted off the laptop. The monitor is now free to be completely lifted off the laptop.
    • Use a Phillips 1 Screwdriver to remove the final four remaining 6.8 mm screws located underneath the back panel.
    • The monitor is now free to be completely lifted off the laptop.
  14. Disconnect the pin connector that attaches the battery to the motherboard. Use a Phillips 1 Screwdriver to remove the two 5.4 mm screws.
    • Disconnect the pin connector that attaches the battery to the motherboard.
    • Use a Phillips 1 Screwdriver to remove the two 5.4 mm screws.
  15. The battery can now be lifted away from the laptop. The battery can now be lifted away from the laptop.
    • The battery can now be lifted away from the laptop.
结论
6等其他人完成本指南。
Aurora Rios
于2018年01月22日注册
841 信誉积分
创作了4篇指南
团队
Cal Poly, Team S16-G1, Banghart Winter 2018 Cal Poly, Team S16-G1, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S16G1
4 名成员
创作了22篇指南
3条评论
Can yo please share the review of this battery? Should I go for original battery or ifixit battery?
Chintan Goyal - 回复
Thank you so much for this Aurora it really helped me work on my ROG, hope my extra notes on Section 11 & 12 help others! Blessings!
Off Duty Pastor - 回复
I have a G751JT-CH71 & I'm not sure if the models are slightly different but I cannot remove the battery by simply lifting it out of the compartment. The battery has 4 lock-in tabs towards the back of the laptop AND 2 additional tabs that are beneath the board. I'm going to carefully pry the battery out, but I'm unsure if there's a recommended method to prying the battery out…
Daniel Sierra - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 12
过去的30天: 58
总计 4,192
