跳转到主内容
Asus ROG G751JL-BSI7T28 Display Assembly Replacement
你所需要的
  1. Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Back Panel: 步骤 1 中的图像 1,1
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 步骤 2 中的图像 1,3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 步骤 2 中的图像 2,3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 步骤 2 中的图像 3,3
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Display Assembly: 步骤 3 中的图像 1,2 Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Display Assembly: 步骤 3 中的图像 2,2
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 步骤 4 中的图像 1,2 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 步骤 4 中的图像 2,2
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 步骤 5 中的图像 1,3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 步骤 5 中的图像 2,3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 步骤 5 中的图像 3,3
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 步骤 6 中的图像 1,3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 步骤 6 中的图像 2,3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 步骤 6 中的图像 3,3
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 步骤 7 中的图像 1,2 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 步骤 7 中的图像 2,2
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
结论
Kristen Gismondi
于11/12/14注册
82,103 声望
创作了200篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,218篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 10
总计 346
