跳转到主内容
Asus ROG G751JL-BB17T29 Keyboard Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Asus ROG G751JL-BB17T29 Keyboard Replacement, Remove the RAM access door: 步骤 1 中的图像 1,2 Asus ROG G751JL-BB17T29 Keyboard Replacement, Remove the RAM access door: 步骤 1 中的图像 2,2
    • Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
  2. Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the 5.3 mm Phillips #00 screw securing the RAM access door.
    • This screw is held in the hole in the door with a washer and will not come out of the hole, even after you unscrew it.
  3. Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 3 中的图像 1,2 Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Insert the point of an opening pick in the seam near the top right corner of the RAM access door and gently pry the door up slightly.
    • The door is held in place by small clips around its edges. Pry until you feel the nearest clips release.
  4. Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 4 中的图像 1,3 Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 4 中的图像 2,3 Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 4 中的图像 3,3
    • Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
    • Pry the door up to release the clips closest to the pick.
    • Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
  5. Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Remove the RAM access door.
  6. Asus ROG G751JL-BB17T29 Keyboard Replacement, Remove the optical drive: 步骤 6 中的图像 1,1
    • Remove the 5.2 mm Phillips #00 screw securing the optical drive.
  7. Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 7 中的图像 1,3 Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 7 中的图像 2,3 Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 7 中的图像 3,3
    • Insert an opening tool into the gap between the optical drive and the laptop.
    • Pry the optical drive straight out of the laptop.
    • Remove the optical drive.
  8. Asus ROG G751JL-BB17T29 Keyboard Replacement, Keyboard: 步骤 8 中的图像 1,3 Asus ROG G751JL-BB17T29 Keyboard Replacement, Keyboard: 步骤 8 中的图像 2,3 Asus ROG G751JL-BB17T29 Keyboard Replacement, Keyboard: 步骤 8 中的图像 3,3
    • Remove the ten 5.2 mm screws holding the main panel in place, highlighted in the photo, with a Phillips screwdriver.
    • Remove the four 5.2 mm screws underneath the center panel, highlighted in the photo, with a Phillips screwdriver.
  9. Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 9 中的图像 1,2 Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 9 中的图像 2,2
    • Remove the two 6.8 mm screws underneath to back panel, highlighted in the photo, with a Phillips screwdriver.
  10. Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 10 中的图像 1,2 Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 10 中的图像 2,2
    • Use the plastic opening tool to pry the keyboard from the base of the laptop.
  11. Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 11 中的图像 1,2 Asus ROG G751JL-BB17T29 Keyboard Replacement: 步骤 11 中的图像 2,2
    • Lift the keyboard carefully, otherwise the ribbon connectors may tear or break
    • Unlatch and disconnect each of the four ZIF connectors.
    • The keyboard is now fully disconnected and you are now free to lift the keyboard away from the computer.
结论
4等其他人完成本指南。
团队
USF Tampa, Team 2-1, Sullivan Fall 2016 USF Tampa, Team 2-1, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S2G1
4 名成员
创作了20篇指南
一条评论
Great work, but you are missing the last few steps of the replacement as all you are showing is how to remove the upper assembly
James Barlow-Jones - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,621
