跳转到主内容
Asus ROG G751JL-BB17T29 Hard Drive Replacement
你所需要的
  1. Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Remove the RAM access door: 步骤 1 中的图像 1,2 Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Remove the RAM access door: 步骤 1 中的图像 2,2
    • Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
  2. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 步骤 2 中的图像 1,1
    • Remove the 5.3 mm Phillips #00 screw securing the RAM access door.
    • This screw is held in the hole in the door with a washer and will not come out of the hole, even after you unscrew it.
  3. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 步骤 3 中的图像 1,2 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 步骤 3 中的图像 2,2
    • Insert the point of an opening pick in the seam near the top right corner of the RAM access door and gently pry the door up slightly.
    • The door is held in place by small clips around its edges. Pry until you feel the nearest clips release.
  4. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 步骤 4 中的图像 1,3 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 步骤 4 中的图像 2,3 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 步骤 4 中的图像 3,3
    • Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
    • Pry the door up to release the clips closest to the pick.
    • Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
  5. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 步骤 5 中的图像 1,1
    • Remove the RAM access door.
  6. Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Hard Drive: 步骤 6 中的图像 1,2 Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Hard Drive: 步骤 6 中的图像 2,2
    • Remove the four 2.4 mm screws securing the left hard drive with a Phillips screwdriver.
    • Use the pull-tab to lift the hard drive housing and pull the hard drive away from the connector.
  7. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 步骤 7 中的图像 1,3 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 步骤 7 中的图像 2,3 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 步骤 7 中的图像 3,3
    • Remove the four 2.4 mm screws securing the right hard drive housing with a Phillips screwdriver.
结论
另外一个人完成了本指南。
Kyle Miller
于10/06/16注册
677 声望
创作了3篇指南
团队
USF Tampa, Team 2-1, Sullivan Fall 2016 USF Tampa, Team 2-1, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S2G1
4 名成员
创作了20篇指南
一条评论
Dose the Asus ROG G751JL have any m.2 port in there anywhere? And what is the maximum capacity of SSD use in the Asus ROG G751JL?
shohebulalam - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 20
总计 5,890
