跳转到主内容
Asus ROG G750JH-DB71 Hard Drive Replacement
你所需要的
  1. Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Ensure the laptop is powered off and unplugged before beginning.
    • Flip the laptop over so the bottom case is facing up.
  2. Asus ROG G750JH-DB71 Hard Drive Replacement: 步骤 2 中的图像 1,3 Asus ROG G750JH-DB71 Hard Drive Replacement: 步骤 2 中的图像 2,3 Asus ROG G750JH-DB71 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Push the switch near the front of the laptop to release the battery from the computer.
    • Pull the battery out and away from the center of the computer.
  3. Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,3 Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,3 Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 3,3
    • Use a pick or your finger to lift up the plastic cover on back of the laptop.
    • Under the plastic cover is a screw, unscrew it using a Phillips #00 screwdriver.
    • The screw has a c lock so it can not be unscrewed completely. Once Its loose pry on the seam using a screwdriver or the iFixit pry tool.
  4. Asus ROG G750JH-DB71 Hard Drive Replacement: 步骤 4 中的图像 1,3 Asus ROG G750JH-DB71 Hard Drive Replacement: 步骤 4 中的图像 2,3 Asus ROG G750JH-DB71 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Remove the cover.
    • Remove the four 4.0 mm Phillips #00 screws holding in the hard drive caddy.
    • Push the caddy towards the open space in its compartment to remove it.
结论
Devin Medeiros
于10/25/22注册
219 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-5, Sinclaire Fall 2022 UMass Dartmouth, Team 5-5, Sinclaire Fall 2022 的会员
UMASSD-SINCLAIRE-F22S5G5
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 129
