跳转到主内容
Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement
你所需要的
  1. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: 步骤 1 中的图像 1,3 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: 步骤 1 中的图像 2,3 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: 步骤 1 中的图像 3,3
    • With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
    • You can now fully remove the battery from the device.
  2. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Track Pad Buttons: 步骤 2 中的图像 1,2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Track Pad Buttons: 步骤 2 中的图像 2,2
    • Remove the large flathead screw holding the back cover in place.
    • Pull the cover off by prying it open starting from the top center and moving outwards.
  3. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 步骤 3 中的图像 1,2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 步骤 3 中的图像 2,2
    • Remove the eight short screws holding in the two metal covers near the bottom.
    • Remove the two metal covers.
  4. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 步骤 4 中的图像 1,2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 步骤 4 中的图像 2,2
    • Remove the battery to access the screws under it.
    • Remove these 16 screws with a regular Phillips head screw-driver.
    • These Phillips head screws will require a longer bit or an extension.
  5. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 步骤 5 中的图像 1,2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 步骤 5 中的图像 2,2
    • Flip the device back over.
    • Pull off the plastic cover behind the screen.
    • Remove the four Phillips head screws holding the screen in place.
  6. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 步骤 6 中的图像 1,2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 步骤 6 中的图像 2,2
    • With the screen removed, pry the piece that has the keyboard and the track pad on it.
  7. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 步骤 7 中的图像 1,2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 步骤 7 中的图像 2,2
    • Remove the two Phillips head screws holding the buttons in place.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 19
总计 415
