简介
If you need to reinstall new RAM slots, you can access the RAM using this guide. You may need to replace RAM if your computer is not running fast enough or has insufficient memory. For this guide, you will need a plastic opening tool and a flathead screwdriver. You will not need to do any difficult steps, but pry the RAM clips carefully.
你所需要的
Place the device upside down.
Unscrew the big metal screw with a flathead screwdriver.
Remove the cover using the plastic opening tool.
即将完成!
结论
