跳转到主内容
Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement
你所需要的
  1. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement, Disc/Optical Drive: 步骤 1 中的图像 1,2 Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement, Disc/Optical Drive: 步骤 1 中的图像 2,2
    • Place the device upside-down. Unscrew the screw at the top of the cover and remove the cover by using a plastic opening tool.
  2. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the screw that is located on the right edge of the removed cover. The screw is in a small opening.
  3. Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: 步骤 3 中的图像 1,2 Asus ROG G74SX-DH73-3D Disc/Optical Drive Replacement: 步骤 3 中的图像 2,2
    • Inside the opening that the screw was in, use a nylon spudger or any thin tool to push against the inside edge of the disc/optical drive.
    • With the disc/optical drive slightly popped out of the socket, pull the rest of it out by hand.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 264
