跳转到主内容
Asus ROG G56JK Fan Replacement
你所需要的
  1. Asus ROG G56JK Fan Replacement, Battery: 步骤 1 中的图像 1,2 Asus ROG G56JK Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Push the slider to the opposite side, while pulling out the battery.
    • Remove the battery from the device.
  2. Asus ROG G56JK Fan Replacement, Hard Drive: 步骤 2 中的图像 1,1
    • Remove the 4 mm screw on the cover using a Phillips #0 screwdriver.
    • Remove the cover for the hard drive by pushing down and sliding it towards yourself.
  3. Asus ROG G56JK Fan Replacement: 步骤 3 中的图像 1,1
    • Slide the hard drive to left and remove it from the device.
  4. Asus ROG G56JK Fan Replacement, Back Panel: 步骤 4 中的图像 1,1
    • Unscrew the four 4mm screws using a Phillips #0 screwdriver.
  5. Asus ROG G56JK Fan Replacement: 步骤 5 中的图像 1,1
    • Flip the computer right side up and start to lift the keyboard. The keyboard/back panel should come off.
    • Do not force the keyboard/back panel off. This could damage internal components and bend the keyboard.
  6. Asus ROG G56JK Fan Replacement, Fan: 步骤 6 中的图像 1,2 Asus ROG G56JK Fan Replacement, Fan: 步骤 6 中的图像 2,2
    • Unplug the red and yellow wires from the port in the motherboard.
    • Lightly pull on the red and yellow wires to release.
  7. Asus ROG G56JK Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the 5mm screw.
    • Remove the 4mm screw.
  8. Asus ROG G56JK Fan Replacement: 步骤 8 中的图像 1,1
    • The fan is glued to the black box that it is inside of. When pulling the fan out, you may experience a small amount of tearing of the black box.
    • Gently pull the fan out of the black box.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 1,771
