跳转到主内容
简介
This guide will demonstrate how to remove and replace the hard drive on your Asus ROG G53SW-XT1.
  1. Unplug the power cable and flip the computer over.
    • Unplug the power cable and flip the computer over.
  2. Unlock the battery by pushing the switch to the right.
    • Unlock the battery by pushing the switch to the right.
  3. Push and hold the left switch, then pull the battery out. Push and hold the left switch, then pull the battery out.
    • Push and hold the left switch, then pull the battery out.
  4. Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard. Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard. Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard.
    • Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard.
  5. Disconnect the keyboard ribbon cables from the motherboard. Disconnect the keyboard ribbon cables from the motherboard. Disconnect the keyboard ribbon cables from the motherboard.
    • Disconnect the keyboard ribbon cables from the motherboard.
  6. Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free. Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free. Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
    • Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
  7. Remove the fourteen Phillips #0 screws.
    • Remove the fourteen Phillips #0 screws.
  8. Flip the laptop over and pull off the bottom cover. Flip the laptop over and pull off the bottom cover.
    • Flip the laptop over and pull off the bottom cover.
  9. Place your fingers along the left edge of the hard drive cover, and slide it to the right, then lift up. Place your fingers along the left edge of the hard drive cover, and slide it to the right, then lift up.
    • Place your fingers along the left edge of the hard drive cover, and slide it to the right, then lift up.
  10. Remove the Hard Drive and case from the laptop. Remove the four Phillips #0 screws from the hard drive case. Remove the four Phillips #0 screws from the hard drive case.
    • Remove the Hard Drive and case from the laptop.
    • Remove the four Phillips #0 screws from the hard drive case.
  11. Slide the hard drive out of the casing.
    • Slide the hard drive out of the casing.
结论
2等其他人完成本指南。
Alexander Lovrien
于2018年02月12日注册
218 信誉积分
撰写一个指南
一条评论
Bottom cover holds only by 9 screws. You don’t need to remove 14 screws. All screws at the bottom with M2 5x7 label (do not remove two small screws. And one scre on the right in the middle without number on the metal plate). You don’t need to remove screw with M2 5x7 label on the right side, second from the corner.
John McCain - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 9
过去的30天: 40
总计 1,397
