简介
This guide will demonstrate how to remove and replace the hard drive on your Asus ROG G53SW-XT1.
你所需要的
Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard.
Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
Place your fingers along the left edge of the hard drive cover, and slide it to the right, then lift up.
2等其他人完成本指南。
一条评论
Bottom cover holds only by 9 screws. You don’t need to remove 14 screws. All screws at the bottom with M2 5x7 label (do not remove two small screws. And one scre on the right in the middle without number on the metal plate). You don’t need to remove screw with M2 5x7 label on the right side, second from the corner.
