跳转到主内容
Asus R541UA-RB51 Hard Drive Replacement
你所需要的
  1. Asus R541UA-RB51 Hard Drive Replacement, Keyboard: 步骤 1 中的图像 1,3 Asus R541UA-RB51 Hard Drive Replacement, Keyboard: 步骤 1 中的图像 2,3 Asus R541UA-RB51 Hard Drive Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Flip the laptop over so that the back panel is facing up.
    • Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
  2. Asus R541UA-RB51 Hard Drive Replacement: 步骤 2 中的图像 1,2 Asus R541UA-RB51 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Turn the laptop upright and flip the screen open.
    • Using the plastic opening tool, gently pry the keyboard panel off of the base.
  3. Asus R541UA-RB51 Hard Drive Replacement: 步骤 3 中的图像 1,2 Asus R541UA-RB51 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Gently raise the keyboard from the base enough to access the underside.
    • Gently pull up on the locking tab to release the ribbon cable. This should take no force to complete.
    • Remove the keyboard.
  4. Asus R541UA-RB51 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,2 Asus R541UA-RB51 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Locate the hard drive in the lower right hand corner in the computer. This device did not have a hard drive so a piece of cardboard was used as a substitute.
    • Remove the two 5.7 mm screws from the base. Use a Phillips #1 screwdriver to remove the screws. Lift up to remove the hard drive.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 664
