当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Flip the laptop over so that the back panel is facing up.
Carefully remove the eight 5.7mm screws on the back panel using a Phillips #1 screwdriver.
Turn the laptop upright and flip the screen open.
Using the plastic opening tool, gently pry the keyboard panel off of the base.
Gently raise the keyboard from the base enough to access the underside.
Gently pull up on the locking tab to release the ribbon cable. This should take no force to complete.
Remove the keyboard.
Remove the three 5.7 mm screws from the CD drive mounting points. Use a Phillips #1 screwdriver to remove the screws.
Gently slide the CD drive away and pull up to remove it from the computer.
取消:我没有完成这个指南。
与2其他贡献者
于08/31/18注册
191 声望
创作了2篇指南
徽章: 6
+ 3更多徽章
WCU-VIRTUE-F18S1G4
4 名成员
创作了5篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 300
