跳转到主内容
Asus R541U Laptop Hard Drive Replacement
你所需要的
  1. Asus R541U Laptop Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the ten screws from the back cover.
  2. Asus R541U Laptop Hard Drive Replacement: 步骤 2 中的图像 1,2 Asus R541U Laptop Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Flip the laptop over and open the case.
    • Use a plastic opening pick or card to pry at the seams between the plastic palm rests and the back cover.
    • The edges will ordinarily be the easiest places to start.
    • Pry all around the case to release the plastic clips, but do not completely remove the palm rest as there are still cables connecting it to the case.
  3. Asus R541U Laptop Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Using a spudger, gently pry open the locking mechanism on ZIF connectors connecting the keyboard and trackpad cables to the motherboard.
    • Once the locking tabs have been flipped up, slide the cables out from the connectors.
    • Remove the keyboard assembly.
  4. Asus R541U Laptop Hard Drive Replacement: 步骤 4 中的图像 1,2 Asus R541U Laptop Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Remove the two screws holding the storage drive enclosure in place using a Phillips #0 screwdriver.
    • Use the lip of the enclosure to lightly pull the hard drive to the right, disengaging it from the rest of the computer.
    • Make note of the orientation of the connection pieces. It will be helpful while installing your replacement.
  5. Asus R541U Laptop Hard Drive Replacement: 步骤 5 中的图像 1,2 Asus R541U Laptop Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Remove the four screws securing the hard drive to the enclosure with a Phillips #0 screwdriver.
    • Gently remove the drive from the enclosure.
  6. Asus R541U Laptop Hard Drive Replacement: 步骤 6 中的图像 1,3 Asus R541U Laptop Hard Drive Replacement: 步骤 6 中的图像 2,3 Asus R541U Laptop Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Insert your new storage drive (Solid State Drive shown here) into the enclosure and secure it with the screws used previously.
    • Make sure that the connector piece for the new storage drive will face the correct way and match up with the connectors on the laptop in the same way the original drive did.
    • Insert the drive into the bay and slide it to the left to reconnect it to the motherboard.
    • Replace the two screws to hold the enclosure in place using a Phillips #0 screwdriver.
结论
另外一个人完成了本指南。
一条评论
My Asus cant show my hard drive on BIOS menu
Siyabonga Dankie Mbutho - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 60
总计 2,953
