简介
Replacing the motherboard is generally the last thing anybody does, however, sometimes it is necessary. If you reach this point, then this guide will walk you through the process.
你所需要的
Locate the locking mechanisms that keep the battery in place and slide them outwards.
The right mechanism will lock in place, the left one you will need to hold in place.
With the Battery, Hard Drive, and RAM removed, the laptop should look like this
Using the JIS 00 screwdriver, remove the 4.7mm screws that are highlighted, there are two in the battery compartment, two on the outsides of the battery locks, and five around the RAM.
Some new motherboards are sold with a fan attached, if the replacement you have does not, then you will need to remove the fan from the current motherboard
To do this, flip the motherboard over once it is removed from the laptop and remove the screws from the bracket holding it in place and remove it
