跳转到主内容
Asus R510CA-OB01 Keyboard and Mousepad Replacement
你所需要的
  1. Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: 步骤 1 中的图像 1,3 Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: 步骤 1 中的图像 2,3 Asus R510CA-OB01 Keyboard and Mousepad Replacement, Battery: 步骤 1 中的图像 3,3
    • Locate the two switches that lock the battery.
    • Then, push the right switch outward to unlock it.
  2. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 2 中的图像 1,2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 2 中的图像 2,2
    • Push the left switch outward and push the battery upward at the same time.
  3. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 3 中的图像 1,1
    • Use a Li-ion battery as a replacement for your battery.
  4. Asus R510CA-OB01 Keyboard and Mousepad Replacement, Keyboard and Mousepad: 步骤 4 中的图像 1,1
    • Shut down the computer and disconnect all external devices connected to it.
    • Turn the computers that it is upside down. Position the computer with the front towards you.
  5. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 5 中的图像 1,1
    • After detaching the battery, remove the two 5mm screws holding down the casing using a Phillips #00 screwdriver.
  6. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 6 中的图像 1,2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 6 中的图像 2,2
    • Loosen the four 12mm screws on the bottom and top panel of your device using a Phillips #0 screwdriver.
  7. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 7 中的图像 1,3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 7 中的图像 2,3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 7 中的图像 3,3
    • Use the grips to slide the panel off.
    • Remove the panel by lifting it off the device.
  8. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 8 中的图像 1,2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 8 中的图像 2,2
    • Remove the three 5mm screws holding down the hard drive and the five 5mm screws holding down the casing using a Phillips #00 bit.
  9. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 9 中的图像 1,2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 9 中的图像 2,2
    • Turn the laptop the right way up and face it towards you.
    • Insert the flat edge of the flat plastic opening tool into the crease of the keyboard cover.
    • While the opening tool is in the crease, carefully pry open the casing by sliding the plastic opening tool along the edge.
  10. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 10 中的图像 1,2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 10 中的图像 2,2
    • Make sure that the entire cover has been released front the plastic pins.
    • Slowly lift the cover open from the front of the laptop but do not completely remove.
    • Note the three locations of the three white and blue data cables connecting the keyboard to the computer's main board.
  11. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 11 中的图像 1,3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 11 中的图像 2,3 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 11 中的图像 3,3
    • Remove each data cable from the motherboard by using your finger or the plastic opening tool to lift the white latch.
    • The cable will slide out of its place.
  12. Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 12 中的图像 1,2 Asus R510CA-OB01 Keyboard and Mousepad Replacement: 步骤 12 中的图像 2,2
    • With the data cables removed and the keyboard module fully disconnected, the keyboard module should come free from the laptop.
结论
Blanche Pinto
于09/28/17注册
437 声望
创作了4篇指南
团队
USF Tampa, Team S3-G4, Nance Fall 2017 USF Tampa, Team S3-G4, Nance Fall 2017 的会员
USFT-NANCE-F17S3G4
2 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 807
