跳转到主内容
Asus Q552UB-BHI7T12 Screen Replacement
你所需要的
  1. Asus Q552UB-BHI7T12 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Asus Q552UB-BHI7T12 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Remove the two screw covers by hand or by using the pointed end of a spudger.
  2. Asus Q552UB-BHI7T12 Screen Replacement: 步骤 2 中的图像 1,1
    • Remove both screws with a Phillips head screwdriver.
  3. Asus Q552UB-BHI7T12 Screen Replacement: 步骤 3 中的图像 1,2 Asus Q552UB-BHI7T12 Screen Replacement: 步骤 3 中的图像 2,2
    • Wedge an opening tool between the two halves of the screen.
    • Keep the two latches together and go completely around the screen to release all the latches.
  4. Asus Q552UB-BHI7T12 Screen Replacement: 步骤 4 中的图像 1,2 Asus Q552UB-BHI7T12 Screen Replacement: 步骤 4 中的图像 2,2
    • Separate the two parts of the screen.
  5. Asus Q552UB-BHI7T12 Screen Replacement: 步骤 5 中的图像 1,1
    • Remove any tape that is holding the screen in place.
  6. Asus Q552UB-BHI7T12 Screen Replacement: 步骤 6 中的图像 1,2 Asus Q552UB-BHI7T12 Screen Replacement: 步骤 6 中的图像 2,2
    • Use an opening tool to lift out the screen after all the tape is removed.
    • The screen may be stuck due to any tape or any remaining glue.
  7. Asus Q552UB-BHI7T12 Screen Replacement: 步骤 7 中的图像 1,1
    • Pull the screen horizontally away to remove the last cable attached to the screen.
结论
Follow these instructions in reverse order to reassemble your device.
2等其他人完成本指南。
2条评论
Can you show the connection on motherboard for LCD cable?
Bustelo Pilon - 回复
Does anyone know where I can get this same model replacement?
Anthony C - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 954
