跳转到主内容
Asus Q552UB-BHI7T12 Battery Replacement
你所需要的
  1. Asus Q552UB-BHI7T12 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove all ten screws on the back of the laptop to remove the cover.
    • Remove the cover.
  2. Asus Q552UB-BHI7T12 Battery Replacement: 步骤 2 中的图像 1,2 Asus Q552UB-BHI7T12 Battery Replacement: 步骤 2 中的图像 2,2
    • Disconnect the wires at the top of the battery by lifting on the tabs protruding out of the plastic frame.
  3. Asus Q552UB-BHI7T12 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the four screws holding the battery in place, two on top and one on each side.
  4. Asus Q552UB-BHI7T12 Battery Replacement: 步骤 4 中的图像 1,1
    • Gently lift out the battery by the side closest to the motherboard first.
    • Be careful of any extra wires that may have attached itself to the battery.
结论
另外一个人完成了本指南。
一条评论
Greetings I have tried to pull the battery out but i have issues making it go out of the place where it clicks, could you make a detailed video on how to safely remove that part without breaking the wires or the soldering on the board???
jorgealanhurtado95 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 3,327
