跳转到主内容
Asus Q551L Repair Motherboard Replacement
你所需要的
  1. Asus Q551L Repair Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,2 Asus Q551L Repair Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Repair Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Repair Motherboard Replacement, Battery: 步骤 3 中的图像 1,2 Asus Q551L Repair Motherboard Replacement, Battery: 步骤 3 中的图像 2,2
    • Unscrew the four screws to remove the battery.
  4. Asus Q551L Repair Motherboard Replacement: 步骤 4 中的图像 1,2 Asus Q551L Repair Motherboard Replacement: 步骤 4 中的图像 2,2
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
  5. Asus Q551L Repair Motherboard Replacement, Optical Drive: 步骤 5 中的图像 1,3 Asus Q551L Repair Motherboard Replacement, Optical Drive: 步骤 5 中的图像 2,3 Asus Q551L Repair Motherboard Replacement, Optical Drive: 步骤 5 中的图像 3,3
    • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
    • Watch out for the wires around the optical drive.
  6. Asus Q551L Repair Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,3 Asus Q551L Repair Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,3 Asus Q551L Repair Motherboard Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Remove the fan by unscrewing the nine screws shown in the images.
    • The four colored wire and the black cable need to be pulled out gently.
    • There will be wires around the fan. Make sure they are not stuck to it.
    • You want to keep the fan if it still in good conditions.
  7. Asus Q551L Repair Motherboard Replacement: 步骤 7 中的图像 1,2 Asus Q551L Repair Motherboard Replacement: 步骤 7 中的图像 2,2
    • Unscrew the seven screws Phillips Head 0.0793 MM on the edges of the motherboard.
  8. Asus Q551L Repair Motherboard Replacement: 步骤 8 中的图像 1,3 Asus Q551L Repair Motherboard Replacement: 步骤 8 中的图像 2,3 Asus Q551L Repair Motherboard Replacement: 步骤 8 中的图像 3,3
    • Disconnect any cables that hold the motherboard.
    • Open up the white adjustable latch first to pull out the tapes.
结论
2等其他人完成本指南。
一条评论
Thanks for posting this guide. Helped me to fix this model computer for a friend. Very well done!
Robert Valentino - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 16
总计 2,397
