简介
This guide will describe how to remove the battery on the Asus Q551L. This is a fairly simple procedure that requires only a screwdriver. The battery may need to be replaced if it cannot hold a charge, experiences heating issues, or simply ceases to function. Make sure your device is turned off and unplugged before removing the battery.
你所需要的
Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
4等其他人完成本指南。
一条评论
Is there a part to order if the solder gives from the mother board connection peice. My cable came up from the board with connection still attached
wolf brown - 回复
