当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
Once the screws have been removed, gently lift the battery out.
Push both metal tabs away from each other on each side of the RAM farthest from battery so that the RAM will pop up.
Pull out first RAM chip.
Push both metal tabs away from each other on each side of the RAM closest to the battery so that the second RAM will pop up.
Pull out second RAM chip.
取消:我没有完成这个指南。
4等其他人完成本指南。
与5其他贡献者
于10/02/18注册
673 声望
创作了4篇指南
徽章: 9
+ 6更多徽章
EWU-MUNOZ-F18S2G1
4 名成员
创作了5篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 608
