跳转到主内容
Asus Q550LF-BBI7T07 Motherboard Replacement
你所需要的
  1. Asus Q550LF-BBI7T07 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Asus Q550LF-BBI7T07 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 2 中的图像 1,2 Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 3 中的图像 1,2 Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  4. Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 4 中的图像 1,2 Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Once the screws have been removed, gently lift the battery out.
  5. Asus Q550LF-BBI7T07 Motherboard Replacement, Hard Drive: 步骤 5 中的图像 1,2 Asus Q550LF-BBI7T07 Motherboard Replacement, Hard Drive: 步骤 5 中的图像 2,2
    • Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
  6. Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 6 中的图像 1,2 Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Gently disconnect the Hard Drive from the connector cable. Lift it out and remove it.
  7. Asus Q550LF-BBI7T07 Motherboard Replacement, Disc Drive: 步骤 7 中的图像 1,2 Asus Q550LF-BBI7T07 Motherboard Replacement, Disc Drive: 步骤 7 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the two 7mm Phillips head screws from the metal disc drive holder.
  8. Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Lift the metal disc drive holder off of the disc drive to remove it.
  9. Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 9 中的图像 1,2 Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Use the Phillips #0 screwdriver to unscrew the one silver 5mm Phillips head screw that connects the disc drive to the motherboard.
  10. Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 10 中的图像 1,2 Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Slowly slide out the disc drive, keeping it level, to remove it.
  11. Asus Q550LF-BBI7T07 Motherboard Replacement, RAM: 步骤 11 中的图像 1,3 Asus Q550LF-BBI7T07 Motherboard Replacement, RAM: 步骤 11 中的图像 2,3 Asus Q550LF-BBI7T07 Motherboard Replacement, RAM: 步骤 11 中的图像 3,3
    • Push both metal tabs away from each other on each side of the RAM farthest from battery so that the RAM will pop up.
  12. Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Pull out first RAM chip.
  13. Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Push both metal tabs away from each other on each side of the RAM closest to the battery so that the second RAM will pop up.
  14. Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 14 中的图像 1,2 Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Pull out second RAM chip.
  15. Asus Q550LF-BBI7T07 Motherboard Replacement, Motherboard: 步骤 15 中的图像 1,3 Asus Q550LF-BBI7T07 Motherboard Replacement, Motherboard: 步骤 15 中的图像 2,3 Asus Q550LF-BBI7T07 Motherboard Replacement, Motherboard: 步骤 15 中的图像 3,3
    • Remove the ten screws surrounding the fan and cooling assembly using a Phillips #0 screwdriver.
    • Remove the two silver 5 mm Phillips head screws that hold the fan in place.
    • Remove the eight black 4 mm Phillips head screws that hold the fan in place.
  16. Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 16 中的图像 1,2 Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 16 中的图像 2,2
    • Disconnect the multi-colored cable that attaches the fan to the motherboard.
    • Pick the fan up to remove it from the motherboard.
  17. Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 17 中的图像 1,3 Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 17 中的图像 2,3 Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 17 中的图像 3,3
    • Use the Phillips #0 Screwdriver to remove the four screws on the edge of the motherboard;
    • Remove the one black 3 mm screw.
    • Remove the three silver 5 mm screws.
  18. Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 18 中的图像 1,1
    • Use the Phillips #0 Screwdriver to remove the remaining four black 7 mm screws on the edge of the motherboard.
  19. Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 19 中的图像 1,2 Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 19 中的图像 2,2
    • Disconnect the five cables that are attached to the motherboard by gently pulling them.
    • Disconnect the four remaining cables attached to the motherboard by lifting the tabs and gently pulling them out.
  20. Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 20 中的图像 1,2 Asus Q550LF-BBI7T07 Motherboard Replacement: 步骤 20 中的图像 2,2
    • Use the metal spudger to pry and lift the silver hinge that is connected to the motherboard to release it.
    • Pull the motherboard out by hand in a counterclockwise motion to remove it.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 18
总计 1,440
