跳转到主内容
简介
If your laptop takes a long time to load any web pages or the laptop overall runs very slow, the hard drive may need to be upgraded. In this guide, we will show you how to upgrade the hard drive.
  1. Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop. Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Use an opening tool to pry open the rear cover. Lift the cover off and away from the board. Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    现在开始购物
    iPhone X Fix Kits
    现在开始购物
  4. Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place. Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  5. Once the screws have been removed, gently lift the battery out using your fingers. Once the screws have been removed, gently lift the battery out using your fingers.
    • Once the screws have been removed, gently lift the battery out using your fingers.
  6. Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws. Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
    • Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
  7. Gently disconnect the Hard Drive from the connector cable. Lift out to remove it. Gently disconnect the Hard Drive from the connector cable. Lift out to remove it.
    • Gently disconnect the Hard Drive from the connector cable. Lift out to remove it.
结论
Chance Woudenberg
于2018年10月02日注册
484 信誉积分
创作了4篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 3
过去的30天: 31
总计 196
