跳转到主内容
Asus Q550LF-BBI7T07 Disc Drive Replacement
你所需要的
  1. Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: 步骤 1 中的图像 1,2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Use a T4 Torx screwdriver head to remove the ten 4mm Torx head screws on the bottom of the laptop.
  2. Asus Q550LF-BBI7T07 Disc Drive Replacement: 步骤 2 中的图像 1,2 Asus Q550LF-BBI7T07 Disc Drive Replacement: 步骤 2 中的图像 2,2
    • Use an opening tool to pry open the rear cover. Lift the cover off and away from the board.
  3. Asus Q550LF-BBI7T07 Disc Drive Replacement: 步骤 3 中的图像 1,2 Asus Q550LF-BBI7T07 Disc Drive Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #0 screwdriver head to remove the three black 7mm Phillips head screws that hold the battery in place.
  4. Asus Q550LF-BBI7T07 Disc Drive Replacement: 步骤 4 中的图像 1,2 Asus Q550LF-BBI7T07 Disc Drive Replacement: 步骤 4 中的图像 2,2
    • Once the screws have been removed, gently lift the battery out.
  5. Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: 步骤 5 中的图像 1,2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Hard Drive: 步骤 5 中的图像 2,2
    • Use the Phillips #0 Screwdriver to unscrew the four silver 5mm screws.
  6. Asus Q550LF-BBI7T07 Disc Drive Replacement: 步骤 6 中的图像 1,2 Asus Q550LF-BBI7T07 Disc Drive Replacement: 步骤 6 中的图像 2,2
    • Gently disconnect the Hard Drive from the connector cable. Lift it out and remove it.
  7. Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: 步骤 7 中的图像 1,2 Asus Q550LF-BBI7T07 Disc Drive Replacement, Disc Drive: 步骤 7 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the two 7mm Phillips head screws from the metal disc drive holder.
  8. Asus Q550LF-BBI7T07 Disc Drive Replacement: 步骤 8 中的图像 1,1
    • Lift the metal disc drive holder off of the disc drive to remove it.
  9. Asus Q550LF-BBI7T07 Disc Drive Replacement: 步骤 9 中的图像 1,2 Asus Q550LF-BBI7T07 Disc Drive Replacement: 步骤 9 中的图像 2,2
    • Use the Phillips #0 screwdriver to unscrew the one silver 5mm Phillips head screw that connects the disc drive to the motherboard.
  10. Asus Q550LF-BBI7T07 Disc Drive Replacement: 步骤 10 中的图像 1,2 Asus Q550LF-BBI7T07 Disc Drive Replacement: 步骤 10 中的图像 2,2
    • Slowly slide out the disc drive, keeping it level, to remove it.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 411
