跳转到主内容
Asus Q534U RAM Replacement
你所需要的
  1. Asus Q534U RAM Replacement, Back Case Removal: 步骤 1 中的图像 1,1
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U RAM Replacement: 步骤 2 中的图像 1,2 Asus Q534U RAM Replacement: 步骤 2 中的图像 2,2
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
    Awesome step!
    Mi Pa Si - 回复
    Thanks yet again!!
    syellon - 回复
    Step 2 I did not realize that the pictures to the right were enlarged for easier understanding of the step. Great walk through even a 66 year old man could understand and do it. Got the I Fix It tools which made opening the case and working with the tiny screws a breeze.
    Steven CARTER - 回复
  3. Asus Q534U RAM Replacement: 步骤 3 中的图像 1,2 Asus Q534U RAM Replacement: 步骤 3 中的图像 2,2
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
    Before doing anything here I would highly recommend disconnecting the buttery. I didn't do it myself at the beginning and when removing this ribbon cable I caused sparks going off the right connector.
    Alex Vasko - 回复
    Great suggestion, Alex! This guide should now reflect a safer and more accurate procedure. Thanks for the heads-up.
    Richard -
    To clarify: you need to flip up the black plastic tab of the recepticle, not the cable. Then don't pull the blue tab up, you need to angle it up just a little bit, about 15 degrees, then slide the cable out.
    Gaspard van Ko - 回复
  4. Asus Q534U RAM Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U RAM Replacement, RAM: 步骤 5 中的图像 1,3 Asus Q534U RAM Replacement, RAM: 步骤 5 中的图像 2,3 Asus Q534U RAM Replacement, RAM: 步骤 5 中的图像 3,3
    • Locate the metal RAM cover
    • Pull the metal tab on the corner of the metal cover to lift the cover from its clips
    • A pry tool may provide a better grip on small tab.
  6. Asus Q534U RAM Replacement: 步骤 6 中的图像 1,3 Asus Q534U RAM Replacement: 步骤 6 中的图像 2,3 Asus Q534U RAM Replacement: 步骤 6 中的图像 3,3
    • While pushing out the metal clips on both sides of the RAM, lift up the RAM to release it
    • Pull the RAM out gently and bring it up from the slot
    • Make sure to pull out first and then pull the RAM up out of place
    On my model, it says I have two DIMM slots. Will there be an extra slot under the silver cover with the oem installed RAM?
    Mi Pa Si - 回复
    There has to be another Slot underneath the motherboard unless its somehow built in. I replaced this 8 with a 16 and the machine now says I have a total 24gb. Any tips on how to get to the other 8 card?
    Mi Pa Si - 回复
    Any idea if the one, 8gb ram stick can be replaced with 32 gb?
    Jorge Huaman -
    Did you ever find the other DIMM slot? I’m looking for it still.
    I replaced the one 8GB DIMM with a 16GB DIMM giving me a total of 24GB like you did.
    I had a hard time finding unbuffered - non ECC memory which is faster than the other kind.
    I wonder if the other kind would work too? I think it would.
    I’m almost sure that there is NOT another DIMM slot on the opposite side of the board.
    ASUS won’t even admit that the 8GB chip can be replaced with a 16GB chip.
    Regis Philbin - 回复
    Do you know if it can be replaced with 32 GB RAM?
    Jorge Huaman -
    Why do steps #2 and #3 need to be done, can’t we just disconnect the battery cable?
    tonyrodriguez - 回复
    Did anyone find the other slot?
    tonyrodriguez - 回复
    This machine has 8 Gb soldered to the board, there is only one DIMM for adding/expanding memory.
    C. Hatton Humphrey - 回复
结论
5等其他人完成本指南。
Kyle Whalen
于10/17/17注册
181 声望
撰写一个指南
团队
UMass Dartmouth, Team S66-G6, Rockett Fall 2017 UMass Dartmouth, Team S66-G6, Rockett Fall 2017 的会员
UMASSD-ROCKETT-F17S66G6
3 名成员
创作了5篇指南
3条评论
One question: I have this model and have determined that I have a bad stick of RAM. I have removed this stick but still have 8 gigs available. Is there another stick that I m not seeing or is this built in?
Elijah Elliott - 回复
saame here must be another stick somewhere
SvGGRK - 回复
There are 4, 2GB chips of ram, hard built into the motherboard. Located right above the SSD m.2 bay, and beside the copper cooling line. This model of Laptop has one RAM bay, I'm not sure how the Built in and Bay RAM work together but for all intents and purposes, just assume you are only using the Bay for RAM. @svggrk @elijahelliott
Nirlicnick - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 42
总计 6,894
