跳转到主内容
加入维修社区 - 创建账户
Asus Q534U RAM Replacement
你所需要的
  1. Asus Q534U RAM Replacement, Back Case Removal: 步骤 1 中的图像 1,1
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
    询问修复机器人
    添加评论
  2. Asus Q534U RAM Replacement: 步骤 2 中的图像 1,2 Asus Q534U RAM Replacement: 步骤 2 中的图像 2,2
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
    添加评论
  3. Asus Q534U RAM Replacement: 步骤 3 中的图像 1,2 Asus Q534U RAM Replacement: 步骤 3 中的图像 2,2
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
    添加评论
  4. Asus Q534U RAM Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
    询问修复机器人
    添加评论
  5. Asus Q534U RAM Replacement, RAM: 步骤 5 中的图像 1,3 Asus Q534U RAM Replacement, RAM: 步骤 5 中的图像 2,3 Asus Q534U RAM Replacement, RAM: 步骤 5 中的图像 3,3
    • Locate the metal RAM cover
    • Pull the metal tab on the corner of the metal cover to lift the cover from its clips
    • A pry tool may provide a better grip on small tab.
    询问修复机器人
    添加评论
  6. Asus Q534U RAM Replacement: 步骤 6 中的图像 1,3 Asus Q534U RAM Replacement: 步骤 6 中的图像 2,3 Asus Q534U RAM Replacement: 步骤 6 中的图像 3,3
    • While pushing out the metal clips on both sides of the RAM, lift up the RAM to release it
    • Pull the RAM out gently and bring it up from the slot
    • Make sure to pull out first and then pull the RAM up out of place
    添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
Kyle Whalen
于10/17/17注册
181 声望
撰写一个指南
4指南评论
One question: I have this model and have determined that I have a bad stick of RAM. I have removed this stick but still have 8 gigs available. Is there another stick that I m not seeing or is this built in?
Elijah Elliott - 回复 分享
saame here must be another stick somewhere
SvGGRK - 回复 分享
There are 4, 2GB chips of ram, hard built into the motherboard. Located right above the SSD m.2 bay, and beside the copper cooling line. This model of Laptop has one RAM bay, I'm not sure how the Built in and Bay RAM work together but for all intents and purposes, just assume you are only using the Bay for RAM. @svggrk @elijahelliott
Nirlicnick - 回复 分享
This is too old but I hope someone can help me. I open the memory section just to clean all the dust accumulated there. After putting everything back laptop is bricked... Battery led is green. Power led is on but laptop is not booting. Any ideas?
Mario Venegas - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 56
总计 8,249
