跳转到主内容
Asus Q534U Motherboard Replacement
你所需要的
  1. Asus Q534U Motherboard Replacement, Back Case: 步骤 1 中的图像 1,3 Asus Q534U Motherboard Replacement, Back Case: 步骤 1 中的图像 2,3 Asus Q534U Motherboard Replacement, Back Case: 步骤 1 中的图像 3,3
    • Remove ten screws with the T5 driver.
    • Use the opening tool to carefully pry off the back case.
  2. Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: 步骤 2 中的图像 1,2 Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: 步骤 2 中的图像 2,2
    • Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
  3. Asus Q534U Motherboard Replacement: 步骤 3 中的图像 1,2 Asus Q534U Motherboard Replacement: 步骤 3 中的图像 2,2
    • Move the black cable located around the CPU fan out of the holder.
    • Remove the following 9 screws:
    • Three Phillips screws
    • Six Phillips screws
    • Make sure not to mix up both types of screws.
    • Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
    • Before placing a new CPU fan/heat sink assembly, the CPU and GPU surfaces must be cleaned off and thermal compound must be reapplied.
  4. Asus Q534U Motherboard Replacement, Hard Drive: 步骤 4 中的图像 1,2 Asus Q534U Motherboard Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Remove four screws with the Phillips #00 screwdriver.
  5. Asus Q534U Motherboard Replacement: 步骤 5 中的图像 1,2 Asus Q534U Motherboard Replacement: 步骤 5 中的图像 2,2
    • Gently lift the hard disk out using the black tab.
  6. Asus Q534U Motherboard Replacement: 步骤 6 中的图像 1,1
    • Using a Phillips #00 screwdriver remove the four screws of the metal casing
    • Remove the hard disk from the metal casing
  7. Asus Q534U Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,3 Asus Q534U Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,3 Asus Q534U Motherboard Replacement, Motherboard: 步骤 7 中的图像 3,3
    • Disconnect the four marked cables connectors at the sockets.
  8. Asus Q534U Motherboard Replacement: 步骤 8 中的图像 1,3 Asus Q534U Motherboard Replacement: 步骤 8 中的图像 2,3 Asus Q534U Motherboard Replacement: 步骤 8 中的图像 3,3
    • Lift the connecting ports up prior to removing the connectors.
  9. Asus Q534U Motherboard Replacement: 步骤 9 中的图像 1,3 Asus Q534U Motherboard Replacement: 步骤 9 中的图像 2,3 Asus Q534U Motherboard Replacement: 步骤 9 中的图像 3,3
    • Remove the screws holding the hinges down on both sides of the device.
    • A pry tool might be needed to lift the hinge.
  10. Asus Q534U Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove nine, 3.2 mm screws to fully release motherboard.
结论
2等其他人完成本指南。
Jacob Pauker
于09/03/19注册
228 声望
创作了2篇指南
团队
IUPUI, Team S1-G9, Hovde Fall 2019 IUPUI, Team S1-G9, Hovde Fall 2019 的会员
IUPUI-HOVDE-F19S1G9
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 22
总计 1,945
