你所需要的
Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
Pull off the back cover of the laptop.
Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
Step 2 I did not realize that the pictures to the right were enlarged for easier understanding of the step. Great walk through even a 66 year old man could understand and do it. Got the I Fix It tools which made opening the case and working with the tiny screws a breeze.
Lift up the black tab next to the silver ribbon cable.
Pull lightly on the blue tabs until the silver cable is free.
Before doing anything here I would highly recommend disconnecting the buttery. I didn't do it myself at the beginning and when removing this ribbon cable I caused sparks going off the right connector.
Alex Vasko - 回复
Great suggestion, Alex! This guide should now reflect a safer and more accurate procedure. Thanks for the heads-up.
Richard -
To clarify: you need to flip up the black plastic tab of the recepticle, not the cable. Then don't pull the blue tab up, you need to angle it up just a little bit, about 15 degrees, then slide the cable out.
5等其他人完成本指南。
4条评论
I’m not sure if they changed the design but I did not have to remove anything other than the case cover to replace the hard drive. Also, there weren’t any fasteners holding the hard drive at all. It was just laying in there and the foam on the cover held it in place. Since I was replacing it with a slightly thinner drive (SSD) I put an extra piece of foam in there so that it would be held securely. The job was only 10 minutes.
I have to identical versions of that model Q534U, one used daily for four years and the other one was dormant in storage as a backup.
I replaced the RAM in both and have 24 RAM now in each, and replaced the batteries in both, as the stored one was completely dead and the one I have been using showed a slight bloating.
NOW… I also bought a new 2TB SSD drive (D: drive) and cloned the C: drive, which is currently in a SABRENT enclosure, using ACRONIS (2022 Version Home Cyber Protect). I did it creating a useable clone. However, even after a BIOS drive assignment to the bootable Sabrent drive, it’s not booting and installing the C: drive.
Acronis Tech Support says I have to physically install the cloned 512 SSD drive into this laptop. I followed all your steps to make all adjustments, but the accessible and swappable drive is the D drive only and I don’t see the C: drive at all (is it on the other side?
How do I access the 512 HDD C: drive to swap out with the cloned one? Or do you know a trick that ACRONIS Tech doesn’t know so that I can clone via USB drive?
The bootable drive is the M.2, just get a larger M.2 and clone the original to it. I will probably put a 1TB in its place.
CSPhone -
