跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Asus Q534U CPU Fan/Heat Sink Replacement
你所需要的
  1. Asus Q534U CPU Fan/Heat Sink Replacement, Back Case Removal: 步骤 1 中的图像 1,1
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U CPU Fan/Heat Sink Replacement: 步骤 2 中的图像 1,2 Asus Q534U CPU Fan/Heat Sink Replacement: 步骤 2 中的图像 2,2
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
  3. Asus Q534U CPU Fan/Heat Sink Replacement: 步骤 3 中的图像 1,2 Asus Q534U CPU Fan/Heat Sink Replacement: 步骤 3 中的图像 2,2
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  4. Asus Q534U CPU Fan/Heat Sink Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U CPU Fan/Heat Sink Replacement, CPU Fan/Heat Sink: 步骤 5 中的图像 1,2 Asus Q534U CPU Fan/Heat Sink Replacement, CPU Fan/Heat Sink: 步骤 5 中的图像 2,2
    • Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
  6. Asus Q534U CPU Fan/Heat Sink Replacement: 步骤 6 中的图像 1,2 Asus Q534U CPU Fan/Heat Sink Replacement: 步骤 6 中的图像 2,2
    • Move the black cable located around the CPU fan out of the holder.
    • Remove the following 9 screws:
    • Three Phillips screws
    • Six Phillips screws
    • Make sure not to mix up both types of screws.
    • Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
    • Before placing a new CPU fan/heat sink assembly, the CPU and GPU surfaces must be cleaned off and thermal compound must be reapplied.
结论
4等其他人完成本指南。
mmedina
于04/07/16注册
749 声望
创作了2篇指南
团队
UMass Dartmouth, Team S66-G6, Rockett Fall 2017 UMass Dartmouth, Team S66-G6, Rockett Fall 2017 的会员
UMASSD-ROCKETT-F17S66G6
3 名成员
创作了5篇指南
一条评论
Is it possible to replace the fan only without removing the full heatsink or is it fused together as one unit?
Bork Bois - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 2,870
