跳转到主内容
Asus Q525U Back Cover Replacement
你所需要的
  1. Asus Q525U Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,3 Asus Q525U Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,3 Asus Q525U Back Cover Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
  2. Asus Q525U Back Cover Replacement: 步骤 2 中的图像 1,3 Asus Q525U Back Cover Replacement: 步骤 2 中的图像 2,3 Asus Q525U Back Cover Replacement: 步骤 2 中的图像 3,3
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
  3. Asus Q525U Back Cover Replacement: 步骤 3 中的图像 1,3 Asus Q525U Back Cover Replacement: 步骤 3 中的图像 2,3 Asus Q525U Back Cover Replacement: 步骤 3 中的图像 3,3
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
结论
另外一个人完成了本指南。
Stewart Crandall
于02/22/22注册
550 声望
创作了5篇指南
团队
Clemson, Team 2-5, Hunter Spring 2022 Clemson, Team 2-5, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S2G5
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 575
