跳转到主内容
Asus Q505UA-BI5T7 Fan Replacement
你所需要的
  1. Asus Q505UA-BI5T7 Fan Replacement, Back Cover: 步骤 1 中的图像 1,2 Asus Q505UA-BI5T7 Fan Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Flip the device over so that the back cover is facing you.
    • Ensure that the device is turned off.
    • Remove the two 10 mm Philips #1 screws from the top two corners of the back cover of the laptop.
    • Remove the remaining eight 8 mm Philips #1 screws remaining in the back cover of the laptop.
  2. Asus Q505UA-BI5T7 Fan Replacement: 步骤 2 中的图像 1,3 Asus Q505UA-BI5T7 Fan Replacement: 步骤 2 中的图像 2,3 Asus Q505UA-BI5T7 Fan Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to gently pry the back cover of the laptop up. Slide the tool slowly along the edges of the back cover to pop it out of the clips holding the cover in place.
  3. Asus Q505UA-BI5T7 Fan Replacement: 步骤 3 中的图像 1,1
    • Gently remove the cover and lift it off of the back of the device.
  4. Asus Q505UA-BI5T7 Fan Replacement, Battery: 步骤 4 中的图像 1,2 Asus Q505UA-BI5T7 Fan Replacement, Battery: 步骤 4 中的图像 2,2
    • Make sure your device is turned off. Remove the 5 mm screws on each respective side of the battery by twisting counter-clockwise with a #0 Phillips screwdriver.
  5. Asus Q505UA-BI5T7 Fan Replacement: 步骤 5 中的图像 1,3 Asus Q505UA-BI5T7 Fan Replacement: 步骤 5 中的图像 2,3 Asus Q505UA-BI5T7 Fan Replacement: 步骤 5 中的图像 3,3
    • Use a plastic opening tool to gently pry off the connected panel.
  6. Asus Q505UA-BI5T7 Fan Replacement: 步骤 6 中的图像 1,1
    • Gently lift the battery.
  7. Asus Q505UA-BI5T7 Fan Replacement, Fan: 步骤 7 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the five 5 mm screws on the fan.
  8. Asus Q505UA-BI5T7 Fan Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Gently remove the white connecter piece with a pair of tweezers.
  9. Asus Q505UA-BI5T7 Fan Replacement: 步骤 9 中的图像 1,1
    • Gently lift and remove the fan from the laptop.
结论
Caylin Haffner
于09/27/23注册
97 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 72
