跳转到主内容
Asus Q504UA-BHI5T13 Touch-pad Replacement
你所需要的
  1. Asus Q504UA-BHI5T13 Touch-pad Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Touch-pad Replacement: 步骤 2 中的图像 1,1
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Touch-pad Replacement: 步骤 3 中的图像 1,1
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Touch-pad Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Touch-pad Replacement: 步骤 5 中的图像 1,1
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
  6. Asus Q504UA-BHI5T13 Touch-pad Replacement, Battery: 步骤 6 中的图像 1,1
    • Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
  7. Asus Q504UA-BHI5T13 Touch-pad Replacement: 步骤 7 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the five 4mm screws around the battery.
  8. Asus Q504UA-BHI5T13 Touch-pad Replacement: 步骤 8 中的图像 1,2 Asus Q504UA-BHI5T13 Touch-pad Replacement: 步骤 8 中的图像 2,2
    • Use the small plastic opening tool to remove the ZIF Connector on the right side of the battery.
  9. Asus Q504UA-BHI5T13 Touch-pad Replacement: 步骤 9 中的图像 1,2 Asus Q504UA-BHI5T13 Touch-pad Replacement: 步骤 9 中的图像 2,2
    • Remove the battery from the device.
  10. Asus Q504UA-BHI5T13 Touch-pad Replacement, Touch-pad: 步骤 10 中的图像 1,1
    • Pull the large data ribbon near the touch-pad out of the way with your hands.
    • Use the Phillips #0 screwdriver to remove the three 3.0 mm screws connecting the touch-pad to the device.
  11. Asus Q504UA-BHI5T13 Touch-pad Replacement: 步骤 11 中的图像 1,2 Asus Q504UA-BHI5T13 Touch-pad Replacement: 步骤 11 中的图像 2,2
    • Use the small plastic opening tool to remove the ZIF Connector on the left side of the touch-pad.
  12. Asus Q504UA-BHI5T13 Touch-pad Replacement: 步骤 12 中的图像 1,2 Asus Q504UA-BHI5T13 Touch-pad Replacement: 步骤 12 中的图像 2,2
    • Pry the end closest to the display up with your fingers and pull the touch-pad out.
结论
Jacob Fritsch
于11/04/19注册
337 声望
创作了3篇指南
团队
IUPUI, Team S1-G2, Henning Fall 2019 IUPUI, Team S1-G2, Henning Fall 2019 的会员
IUPUI-HENNING-F19S1G2
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 282
