简介
In cases of a damaged hard drive or failure to boot, removing the defective hardware from the computer is necessary. This guide demonstrates how to remove the hard drive from the Asus Q504UA-BHI5T13.
Required Tools:
- T5 Torx Screwdriver
- Opening Tool
- Metal Spudger
- Phillips #0 Screwdriver
Completing this guide may take 20 minutes, some experience with electronics is recommended.
It is also recommended to have a replacement hard drive, but it is not required. Do not place the hard drive near any magnets, as this will likely damage the hardware.
你所需要的
Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
Use the Phillips #0 screwdriver to remove the eight 4mm screws around the hard drive casing (located next to the Right [R] speaker).
Start off with the four black outer screws so that the casing can be released from the laptop unit.
The next sequence of screws to remove are the four silver screws.
5等其他人完成本指南。
一条评论
I used your steps to replace the 128GB SSD with a larger drive. When I booted up, the new SSD appeared, the REMOVED 128GB SSD appeared, but the 1TB HHD data drive disappeared. Any tho’ts? Wish I could give you more than 30 points. Thanks. I was down to 17GB on the original drive.
